dash lightbulbs
silly question but here goes,[8D],,, is their an easy way to replace bulbs in tac and spedo .mine seem to have left the building,and its dark , the rest of them need to be replaced also but i think i can get to them, ,,thanks ,
RE: dash lightbulbs
SORRY ITS 1975
RE: dash lightbulbs
You can reach up under the dash and get them. Best bet is to loosen the speedo/tach from the dash pad so you have some extra play to get your hands up there. Check out your favorite service manual so you know where they are before you start feeling around up there to try and find them all. bill. |
RE: dash lightbulbs
thanks, do i need to disconect battery?or can`t you get fried?.
RE: dash lightbulbs
Yes, disconect the battery first.PG
RE: dash lightbulbs
Pete's right. Always disconnect the battery before you do anything with the wiring in a car. If you are stuck under the dash and ground a wire, you may fry several electrical parts before you know what happened.
