Fuse box labeling
Hey guy's, I have 1979 corvette. I have 20 amp fuse that blows the minute you put it in.
I can read the box anymore to see what it is for. The fuse is power all the time. So not sure where to start looking. What I need is to finda labeling for it. Thanks |
RE: Fuse box labeling
I have a '78 wiring diagram. 25A-heater & A/C, 20A-turn sig & back-up, 20A-throttle solenoid, 25A-wiper, 20A-ctsy, cig ltr,& clock,anti-theft,dome, 20A-tail, side,under hood, 20A- stop, haz, key buzzer, 20A-radio & rear defog. Hope this helps, it's a combination my diagram and '78 owners manual.
Can you tell what things aren't working?
Hey guy's thanks for the info. The info Mr Bill sent looks like it is the CTSY CLK fuse. That makes good sence to me. [/align]I did have a few thing not working, But was able to get all that repaired. Except for the Power Antenna. I disconnected the relay to it and that didn't fix the short.[/align]I had the center console removed and reinstalled with all new screws. There where no screw behind it before. So I put some in there. The console is much tighter...And that is where the clock is also. So I might be grounding out behind there...So I will take it down over the weekend and see.[/align]Wish me luck. If not I will be back.[/align]Thanks again for your help[/align]
