Headlights do not close
Need help on what is the best place to begin when headlights do not close.
Thanks, new owner of 1976 |
RE: Headlights do not close
I am not exactly sure about a '76, but on a '79 there is a small vacuum switch located under the center of the steering column under the speedo/tach cluster. Push the plunger up or in and you will restore vacuum to the system.
[sm=icon_cheers.gif] Edit - A previous owner may have left the lights up due to a problem with the system, usually a vacuum leak. |
Hey rvitale if you still have problems try this site; www.corvette-101.com/vacuum.htm Should help you isolate and repair the problem. Good luck!
