Muncie 4 Spd Box, Lube weight ???
I just drained out the original lube in my 73's diff. & I figured while I'm at it I'll do the 4spd trans also, is the lube weight the same as the Differential ? , I used 80w 90w with CRC posi additive, the rear is a 3:36 I believe. The power train and engine just turned 30K miles two years ago.
Thanks for any feed back ,,,,,, New member & older Vette owner Glenn [IMG]local://upfiles/1066/AC00B8686B0B4F60BD6586AD640D59C8.jpg[/IMG] |
RE: Muncie 4 Spd Box, Lube weight ???
Well I guess nobody knows, so I'll check with a dealership.
