No electrical power - Corvette Forums - Corvette Enthusiast Site
Thread Tools Search this Thread
Old 06-05-2017, 10:08 PM
Default No electrical power
Brought the 73 convertible (manual) home the other day. Let someone else drive it and they didn't know how to take the key out. Got the key out - press in clutch, put car in reverse, turn key. Now Imhave no power at all. The battery is fine, but I'm not getting any power to any system. I'm looking for recommendation on where to start looking.
thanks,
Mike
Old 06-06-2017, 10:55 PM
I'd start looking at the actual ignition switch which is located on the steering column near the firewall. Maybe the linkage was affected by the abnormal key removal procedure. If the linkage isn't moving when you turn turn the key, then your problem lies in the area of the ignition lock and will require removal of the steering wheel. A Factory Service Manual would be very helpful.
This assumes that you are getting no starter or accessory power w/ the key in.
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Featured Sponsors
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
