Rear end?
Hello, I have a horrible noise when I let off the accelerator and it is even worse when I back up. It is constant in reverse. Almose like a scrubbing sound. No noise whatsoever going down the road and more like a rattle only lasting a second or so when I let off. She is parked till I get her fixed, anyone have a clue? I checked the u-joints all 6, and they seem to be fine no play. Thank you for your help.
RE: Rear end?
Usually when you get roaring when you let off the gas, you have pinion bearing problems, may be in for complete bearing replacement in the differential, if not a ring and pinion.
RE: Rear end?
Anyone know a good fair differential mechanic in the east Tennessee area. I called several here in Knoxville and they are scared of it. Thanks I just cant stand the thought of not driving her in this wonderful June weather.
Tim |
RE: Rear end?
Several of the Corvette places sell rebuilt differentials, get online and check it out. [8D]
RE: Rear end?
I had the same problem with my 74 plus the previous owner let wheel shop bend the strut rods to align and some other problems i had my mechanic rebuild the differential plus new strut rods and all new bushings plus yokes and 1/2 shaft u joints took him a few weeks but works cheap (he is a automechanic teacher ) and works out of his own garage in evenings name is jack hayes if you need his number give me a email at richardroe@mis.net and ill send it to you
