Rochester quad problem?
Anyone have Rochester quad stalling at cold temperature?
Example: drive up to a stop sign after cold start, throw the gear in neutral and engine dies out. It just started happening and it's annoying. I have to warm up the car at least 5 minutes before heading out. I thought it was vacumm leak but can't find any leak at this time and choke plate is 1/8th inch from closed. ** scratching head ** Thanks |
More details on engine. Stock or modified, how if so.
Originally Posted by 73shark
(Post 69250)
thanks |
Could be a vacuum leak or maybe it needs a little less than 1/8" choke when cold and running.
Has it ever run OK cold? It's OK in Park but dies in Neutral? |
(Post 69258)
Has it ever run OK cold? It's OK in Park but dies in Neutral? I will look further into the vacuum anomalies. I do have to give throttle to pop open the headlights also so vacuum at low idle is a suspect at this time. Thanks for the reply. |
