Speedometer cable leak
I'm leaking transmission fluid from the speedometer cable. Looking at the cable and cable gear assembly I don't see how it wouldn't leak. The way the gear fits into the housing there appears to be no seal that would keep fluid from making it's way up into the cable. Am I missing something?
Neild |
I would check the level of the transmission fluid or oil depending on which type of transmission you have. It sounds like it might be overfilled. |
Originally Posted by 73shark
(Post 76557)
I would check the level of the transmission fluid or oil depending on which type of transmission you have. It sounds like it might be overfilled. Thank you for the response. Neild |
Let us know how it works out.
Before and after
The attached pictures are before and after of the speedometer bullet gear shaft seal. It's easy to see were things went wrong.
https://cimg9.ibsrv.net/gimg/www.cor...2b394bb769.jpg https://cimg1.ibsrv.net/gimg/www.cor...bd73eecfad.jpg |
Thanks for the feedback. :)
