stock valve size
I have an 80 with the L-82 and i was wondering what size valves i have.
and possibly rear end gears but from what i understand there was about six rear end options |
RE: stock valve size
I'm guessin' valves are 1.94's.
Rear end..... get one rear wheel off the ground, leave trans in neutral. Mark the drive shaft and the rearend housing at a common point. Rotate the tire one full rotation and count the rotations of the drive shaft. This will get you real close as to the ratio of your rear end. 3 turns, 3.07:1 4 turns, 4.11:1 These are rough numbers, but will get you in the ball park. |
