taking the dash apart
I'm trying to get behind my driver's side dash to replace bulbs and such but don't know what all will have to be unplugged. I took all the screws out that the Haynes manual suggested but still no luck. Thanks.
RE: taking the dash apart
Hi jsholm2, the safe way to get the drivers dash out is to loosen the steering column at the rag joint, but I just removed the 2 bolts that holdthe steering columnto the dash and lowered it enough so that I could pull the dash out far enough to reach back there to get to the bulbs.
Pg. |
Wonderful! Thanks man
Granted I'm "bitching" about reality, but having to take the dash apart to replace bulbs, alittle extreme. And "Haynes" should have stuck to "underwear." I have a bulb out somewhere in the dash also and now I'm thinking about a "night vision device." LOL
Texas Jim,
I was able to take out the part of the dash with the speedometer and tac without removing the steering wheel. I have a 79 and tilted the steering wheel down all the way and with a little pushing and pulling I was able to squeeze it out. Forgot to put the speedometer cable back in, need to go back and do it again. |
It is real hard to disconnect the wires from the back of the gauges, but you can twist it around and take it off then pull it out.
