"Rubbing" noise - left rear wheel
On my 87 Vette conv't, every once in a while, while backing up, I can hear a "rubbing" noise in the area of the left rear wheel. My mechanic has taken apart the whole rear wheel, brakes, etc and has found everything to be in tip-top shape. There are no rub marks inside the wheel well, and no "contact" marks. Does this sound like it could be the wheel bearing starting to break down.
mypetu39 |
RE: "Rubbing" noise - left rear wheel
Could be, also check u-joints in half shafts and drive shaft. A dry joint can sound similar to "rubbing" noise.
I've noticed the same thing. I'm a new owner of a '94. I think it must be some system getting preset (ABS maybe). Like cocking the hammer on a gun to get ready to fire. It does it consitantly and only the first time I back up after starting. I have not identified the cause, but I don't think I'll be paying anyone to tell me my car's OK...thanks to you.
