1987 VETTE shuts down after 15 min.
Old 05-31-2018, 08:30 AM
John D's Avatar
Default 1987 VETTE shuts down after 15 min.
1987 corvette replaced distributor/complete,fuel pump,all injectors,ECM/PROM.Car still shuts down after 15 min.Won't start until it cools down.
Old 06-01-2018, 09:08 AM
Try putting a fuel pressure gauge on it and monitoring the fuel pressure right before shutdown. If the pressure goes to zero, check the fuel pump relay. If it is operating normally then I think it points to the fuel pump.
Old 06-26-2018, 10:02 PM
Wes King's Avatar
I have a beautiful white 1994 Corvette, with a repetitive problem of turning off, simply dies on hwy, back roads or anywhere. I’ve read most post of same caliper, and I have not read the remedy of my Vettes problem. Same symptoms will start back up after 10-15 min. Dash displays sys (3x) no codes. Service engine soon and batt alerts are displayed until it cools and restarts. No alerts . No stall, just dies.
where to begin my search for correct repair sequences..? I’ve only had this Jewel for 30 days, would like to fix prob and drive the living Heck out of er. I’m pretty good with suggestions , as well to be appreciated ..
wes.
Old 06-27-2018, 12:41 PM
Ladybug's Avatar
My husband asks if you have a standard coil. Says that could be the problem.
Old 06-27-2018, 02:42 PM
Wes King: Welcome to the forum.
If you have a check engine light then you need to have it scan for codes. Most auto parts stores will do it for free.
Old 06-27-2018, 11:13 PM
Wes King's Avatar
Thanks shark,
i have readers and jumper wire. Service engine soon ONLY comes on with the Batt Alert on dash module.
when she starts up again?, no codes or cluster/ dash module alerts. I believe I can follow precise instructional suggestions. I’m wondering which possible repair would be best to start with .?
fuel pressure. Column/ ignition, distributor , coil, abs, tps, or any other possibility?
thanks for the info. Glad to be add...
Old 06-27-2018, 11:15 PM
Wes King's Avatar
I did do not have any History codes displayed
Old 06-28-2018, 09:11 AM
Ladybug's Avatar
Wes - my husband says, "I am thinking he has a HEI ignition, so most likely his problem may be a collapsed fuel sock in the fuel tank."
Old 07-01-2018, 09:36 PM
Wes King's Avatar
Thank you ,,
”my husband says”. I’ll give er a look see..
Old 08-10-2019, 12:15 AM
adrian316's Avatar
Default have you checked your catalytic converter
On my 89 it would shut off after it warmed up a little bit then i took my catalytic converter off and found out it was melted apart from the inside and it runs fine now
Quick Reply: 1987 VETTE shuts down after 15 min.
