1988 Hood Stuck
My hood is stuck closed on the passenger side.. Any advice appreciated..... Will the tool for hoods in the ecklers catalogue open the passenger side???
RE: 1988 Hood Stuck
try driving around a bit. the vibrations caused my stuck hood to come loose. you can also trying to pull on the cable by the release lever with a pair of pliers. then once you get your hood open, grease it up and ajust the cables if necessary
RE: 1988 Hood Stuck
Also, while pulling on the release handle, have a person on either side of the hood lifting it.
