1993 help won't start
I have. 1993 convertible ran fine. My son drove it home now won't start if I hold the throttle to the floor it will almost fire but won't actually start thought it might be the throttle position so I changed it it did not help? Please help:mad::confused:
Check the fuel pressure w/ the key on, engine off. |
What should the fuel pressure be?
Originally Posted by 73shark
(Post 72174)
Somewhere in the 50-60 psi range
Fuel pressure checked 42 and blead off to 20 within about 5 min. So I replaced the fuel pump and strainer still same condition? Same fuel pressure and bleed. Any other ideas as what it could be? Driving me crazy.:mad:
(Post 72195)
Need three things to run, fuel, air, and spark. You are lacking one or more of these.
Any DTCs? |
I have fire but can the optispark fail intermittently?when I pull the codes I get none.
(Post 72209)
Any DTCs? |
I have read where the Optispark is the weak link on that model. It was subject to failure due to water getting into it. it sounds like it might be time to replace it.
Could be your fuel pressure regulator. I believe it's on the rail. It has a diaphragm in it and could be leaking.
Opti-spark
Originally Posted by blueshark
(Post 72365)
