1995 door panels
After a recent purchase of a '95 vette, I've noticed that the top portion of the door panels on both sides at loose. I'm not sure if they are secured with clips or some other fastening device. I didn't want to be surprised after taking the panels off and it's something entirely different. Need some advice!
RE: 1995 door panels
Here is a repair option, which I have heard mixed reviews on:
C4 door panel attachment repair -- 1 of 1 Date Published: 2003-09-23 Submitter's Name: Jason Sette Email Address: j-sette@yahoo.com Corvetteforum.com Member Alias: 94vette Finally, after 4+ years of ownership, I have repaired the dreaded floppy door panel syndrome that has plagued my car. You too may be suffering from this disease, where the top of the door panel pulls off the door frame and kinda hangs there, flopping around, only be held on by a few door screws and pegs at the bottom. The reason this occurs is because over time, the door panel top edge will pull away from the door frame top edge (due to heat and wear & tear), and the panel will never fit back on the door frame because it is warped. The solution is to make the door frame higher in order to once again fit inside the top curved portion of door panel. I went to Lowes and purchased a bag of four 1" x 1/2" zinc-plated corner braces and screws by National (# 38613 227385 under the UPC bar). They are "L" shaped braces with a screw hole on each end (each end is 1" long by 1/2" wide, so both ends are identical). Removing the door panel, you will see a row of several 10mm screws running the length of the top of the door frame. These are what we will use to affix the corner braces to the door frame. Select 2 of the these screws (I used the screws that hold the felt-covered window rub brackets -- one is at the back of the door, and the other is about the middle of the door), unscrew them (10mm socket), put one "L" corner brace over each hole in the door frame, and reattach the screws. Again, put 2 corner braces on each door. The "L" braces should face the inside of the car. Then I took a hammer and chisel and took a few whacks to the corner braces in order to bend them inward SLIGHTLY (towards the inside of the car) to conform to the shape of the door panel. Not too much whacking, please, as you only want them to bend about 10 degrees -- any more and the door panel will slide off. Now reattach the door panel by guiding the top of the panel onto your new braces (attack the door frame from above, lowering the door panel over the door frame and "L" braces, making sure to line up the edges of the door and screw holes). The curved, top edge of the door panel should fit over the door frame and the "L" braces will now fit inside the curved portion of the door panel to hold it on. Then reattach all the door handle parts and screws. That's it -- good as new and tight as a drum. Total cost = about $4 and an hour of your time! |
Thank you very much!....I'll try that
I tried the suggestion for my 92 passenger side door panel and it seems to have worked! Thands for the info!:)
