6 speed hard to shift
Hello out there everybody ! Just bought 1989 with 6 speed , runs great ,has new clutch assembly,but is hard to put into gear when transmission is cold ! Shifts great after up to temp!! Reverse really hard when cold!!Any ideas? Wrong lube maybe?? Thanks
RE: 6 speed hard to shift
I would try switching the trans fluid. I highly recommend using GM Syncromesh found at your local GM dealer.
I am planning to switch my Trans Fluid pretty soon, but I was going to go with Royal Purple (I've heard a lot of good things about their products). Why do you recommend the GM Syncromesh over anything else on the market (aside from the fact that its the factory fluid)?
ORIGINAL: PAY2PLAY I am planning to switch my Trans Fluid pretty soon, but I was going to go with Royal Purple (I've heard a lot of good things about their products). Why do you recommend the GM Syncromesh over anything else on the market (aside from the fact that its the factory fluid)? |
ok, will try changing fluid . thanks for response !!
Guess i should of checked clutch resevoir !!ha Just bought car last Friday ,10/14/05 . Was almost empty , little dot3 and shifts smooth now when cold. Didnt think it was clutch because wasnt grinding trying putting into gears. Thanks
