'89 Starts Cold Runs Fine Won't Start When Turned Off
1989 - Starts great, runs right until I turn it off. When I try to start it again it doesn't want to start until cooled down. Have had it checked by two machanics -- neither could locate a specific problem. One recommended a new coil and/or fuel pump. The other recommended new spark plug wires. What's up? Thanks for any suggestions.
Sorry - originally posted as a '84 (another of our cars) |
RE: '89 Starts Cold Runs Fine Won't Start When Turned Off
lets assume its cranking over fine. when it doesnt start check for spark,if ya got spark check for fuel.you can check for spark by pulling off a plug wire and putting a screw driver in the boot ,hold it 3/8 of an inch to ground then have someone crank it over.you want a nice crisp spark jumping off the screw driver to ground.fuel testing need test equiptment
by the way if those wrenchs checked this car while it didnt start one is an idiot,dont go back to that one
Fuel injectors. Starts fine cold then hard to start when its hot or won't start at all after the initial start?
ORIGINAL: LeesVette Fuel injectors. Starts fine cold then hard to start when its hot or won't start at all after the initial start? |
ORIGINAL: extanker ORIGINAL: LeesVette Fuel injectors. Starts fine cold then hard to start when its hot or won't start at all after the initial start? acted EXACTLYlike you describe.. yes itcould belots of things.. but my INJS fixed mine. |
ORIGINAL: 3BlkC4Ragtop ORIGINAL: extanker ORIGINAL: LeesVette Fuel injectors. Starts fine cold then hard to start when its hot or won't start at all after the initial start? acted EXACTLYlike you describe.. yes itcould belots of things.. but my INJS fixed mine. you rebuilt the injectors?they sell rebuilding kits for them? |
I don't know if they sell the injector kits but I know the ones for LT-1's can be R&R'd.
ORIGINAL: LeesVette I don't know if they sell the injector kits but I know the ones for LT-1's can be R&R'd. |
