92 rear suspension lube
Hello, I was wondering if there are grease points on the rear of my car. I am going to check the differential fluid. While I am under there thought I would lube anything that needs it. I keep reading about rear suspension lubrication on these cars but dont know what they mean. Thanks
Most C4's have grease fittings on the rear control arms at the pivot points and your gear lube for the differential should use the posi track additive.
