95' always runs hot
would removing the thermoatat make the car run cooler???? I was talking to a guy with a 94 vette that always ran hot , he change a switch by the radiator so the fan runs all the time and stays cooler,, any one know what this is or how to do it?
How hot is it running? Analog & digital? Neeed more details.
95 Fans on "lo" at *228 & "Hi" at *238. Inadviseable to remove thermostat. |
its analog, but if i sit at a light the temp gauge pretty much burries over 260 to 280,,
fan does come on until the needle is almost all the way down,,, what can I do?? |
What's the digital temperture? The analog gauge is not as accurate as the digital. Seems like the fans are operating ok.
There is a small access hole on the right side of the radiator shround. Look & see if the area is full of trash, etc. I'd try a flush & fill & see if that helps. Maybe also pull the top of the radiator cover & wash out the fins. There are lots of things you can do. Donot run the engine without the thermostat. Don't know if you have an owner's manual, so check this out. http://corvette-world.com/1995-corve...ree-a-148.html |
viscount where is the digital reading at??? if i flush is there a certain antifreeze i should use??
Originally Posted by bam
(Post 66552)
If not the trip monitor is located to the left of the DIC. Hit the gauges button & you will get a readout for "temp"-"battery"-"Tranny" & "oil temp". |
The analog gauge is not linear. What you may think is 260 or 280 may not actually be. You really need to use the digital gauge for accurate coolant temps. I bet it's not running nearly as hot as you think.
