Can you identify this wire
https://cimg7.ibsrv.net/gimg/www.cor...960ce2cf9c.jpg
This wire I just noticed is not connected? Disconnected the battery recently... car runs fine, but has been running HOT. Not sure if it's associated with the cooling fan not running - which will be my next post. Any suggested as to where this should be connected? Thanks! |
If you have a tester check to see if it’s a positive or negative lead. If you’re having cooling fan issues- that may be the problem
Thank you! I'll try that - any idea where / what it should be connected to?
Originally Posted by Streamachine
(Post 76517)
I'll try that - much appreciated!
