Cruise control vacuum lines
Cruise stopped working, checked the vacuum lines and they're pretty dry-rotted. Going to replace them (hopefully that's the culprit). Can't trace the line that runs into the firewall, can't even get my hand down in there, to tight.
What's the best proceedure? Oh, it's a 1995 w/92k miles. |
RE: Cruise control vacuum lines
The vacuum line through the firewall goes to your brake switch and it is directly under the brake booster. It is the vent to release vacuum from servo when you step on brakes.
Any diagram or pic of what i'm looking for once i'm up inside the brake pedal. And could it be the switch?
