Fluid Change
I have a 96 LT4 that has 34000 miles on it. I know for a fact that the tranny and rear end lube has never been changed and GM says that it doesn't have to be. I would think after 13 years that it wouldn't hurt. Also, what about spark plugs and wires. What are some of the opinions on this? I would think that there are much better lubes out there now.Any recommendations?
Thanks in advance Bucketman |
RE: Fluid Change
If you dont drive underwater or race on the weekends dont bother the change. Just check and top off w/ factory recommended fluids. The factory fluids are some of the best for the every day driving.But if you want to go by the book the owners manual the car came w/ with has a service schedule.The wires are a matter of having them changed if the are causing a performance issue. They could last 100k miles and never cause a problem. The plugs- could not hurt if you change them, but my money says they are probaly ok if the motor is running ok.
RE: Fluid Change
On the plugs, I was concerned about the siezing that might happen since they have been in there so long. I also heard that if pull the wire, that there is a good possibility that you might wreck it. The car runs fine, just thinking about preventative maintance.
RE: Fluid Change
There is a tool that looks likes a pair of duck bill pliers used to pull the wires at the boot. The plugs getting stuck is a hit or miss, use a little neversez when you to the change out.
RE: Fluid Change
I gotta' agree with yankee.. Although vacuum lines can dryrot, the systems you refer to are sealed - rearend fluid, plugs, wires. Tranny fluid could separate or gum up - do the fluid and filter for the tranny, and check vacuum hoses.
