Front oil seals
Hey guys. I finally am into my winter project of repairing oil leaks. Got evreting off the front except for timing cover. Not sure if I should remove it. When I removed the opti-spark I found two very hard cracked O rings that just crumbled in my greasy finger tips. This I am sure was probobly the culprit. Looks like most of the oil leak was from this. Would these O rings allow alot of oil to leave the engine? Can't really tell if other seals and timing cover are leaking. What do you think? Also I live in desert of California and am replacing the radiator on this baby. Direct fit or Be Cool. What do you all think about that? Thanks
[IMG]local://upfiles/3556/CA74C303B3454BA5A8A0DECB2EA7EA9A.jpg[/IMG] |
