Gas pedal stuck
I punched the gas pedal off the line and she got stuck.I turned the key off and pulled over safely.After several attemptsto clear the pedal i started the car and was doing 30 mph without touching the pedal.Then two minutes later she went back to normal.I see some wear on the cable at the fire wall.Anyone else have this problem or solution? (84 vette C4)
RE: Gas pedal stuck
Either your throttle linkage is rubbing on something or cable is binding. Check the operation of both throttle bodies for smooth action.
RE: Gas pedal stuck
YA, SHURE SOUNDS LIKE CABLE ,CHECK YOUR BRACKETS TO:D
