gears
I know ive posted stuff about this before... but does anyone know what size gears the 94s came with? or if they varied, how to find out. i just bought a Hypertech Power Tuning Module and i need to know what size gears i have to tell it my gears are a different size. It is an automatic if that counts for anything. Thanks
RE: gears
yes they did vary
All Manual transmission cars from 85-96 have the D44 rear axle. All 84s and all automatics have the D36 rear axle. RPO Codes: G92: Performance Rear Axle Ratio, means nothing really. GU2: 2.73 verts option 15 pinion teeth, 41 ring teeth, 7.875" ring gear outside diameter GM1: 2.59 standard rear for D36 cars 17 pinion teeth, 44 ring teeth, 7.875" ring gear outside diameter G44: 3.07 standard rear for 4+3s, option on A4s 3.07:1 ratio: 14 pinion teeth, 43 ring teeth, 7.875" ring gear outside diameter 3.07:1 ratio: 14 pinion teeth, 43 ring teeth, 8.5" ring gear outside diameter (manual transmission) GW4: 3.31 only for 84s with Z51 only GT7: 3.33 available on Late-89-90 6speeds GM3: 3.45 standard rear for later 6speeds GHO: 3.54 available on early-89 6 speeds, and as an option on a few later years. |
RE: gears
Check your line sheet for those codes and if the car is original, you can see what ratio you have. [8D]
RE: gears
Raisin, where did you find the line sheet break downs?
RE: gears
thanks mech but hwere do i find my line sheet?
RE: gears
If it is still there, it might be on the wall of your console. [8D]
RE: gears
ok so i found the code sheet... how do i know which code it is?
RE: gears
Read Raisin's post, option codes are usually a letter followed by 2 numbers. He has the option codes for gear ratio's. [8D]
RE: gears
you guys are so smart [8D] thanks for all of your help. now another question... if i went out and bought the Hypertech Programmer III, that would allow me to customize the gears i have in my car and everything working with a STOCK CHIP... i dont have the hypertech chip. I bought the hypertech power tuning module thinking it was the chip but apparently it isnt. So i just need to know if the stock chip is customizable as far as gear ratios and tire sizes and stuff like that go...
RE: gears
If I'm not mistaken, there is no chip in your car. It has a EPROM, which the power tuning module reflashes the stock tuning curve to a more high performance curve. [8D]
