hazylight covers
The plastic lens covers on my fog lights are hazy.Also some of the other light covers as well.Is there something I can use to clear them up?
RE: hazylight covers
Sounds like you may have condensation on the iside of the covers. Take one off and check that. You may have to replace the gaskets.
If there's no moisture in the headlight and its just a hazy lens, you can buff it out using Meguiar's PlastX. It restores your lens clarity. Takes some elbow grease but I highly recommend it.
You can also use toothpaste. This was just posted in another forum. Haven't tried it myself.
ORIGINAL: LeesVette You can also use toothpaste. This was just posted in another forum. Haven't tried it myself. |
Thanks for yourhelp.Ill certainly try everthing.
Brasso you can get it at grocery stores cheap and it lasts along time on the back of the can it says it works on plastic watch crystals.I have even used it on the clear plastic on my insturment panel to remove small scratchs it works great.
