HELP ! fuel supply problem
1984 vette crossfire inj, I just had the injectors re worked when I put it back together now when I turn on the ignition the rear throttle body just startsflooding withfuel with or without the wires hooked to the injectors,what would be doing this? could it be the fuel pressure regulator has gone bad or stuck ,or should I be looking at something else?any and all suggestions welcome!!!
RE: HELP ! fuel supply problem
I dont know about Cross Fire injection, but........
I would like to wecome you to CFs.We have a friendly and knowlegable bunch of 'Vette Heads' here. :) How about, you go to the 'New Member' forum, and introduce you and your Vette. :eek: We sure would like to see pics too, if ya got em. ;) |
Can you tell if the fuel is coming thru the injector or around it? If thru it,it's assembled wrong or stuck. If around it you'll need to disassemble things until you find the broken seal or cut o-ring? Good Luck!
Ron |
