instrument panel lights .. replace 1987
The right side of my 87 inst panel lights are out,, all guages work fine just cant see them at night.. How much is involved in changing bulbs
RE: instrument panel lights .. replace 1987
Hi, JC. If you look up at some of the other threads this problem has been addressed pretty well. Good luck with it. And if you do have any questions after reading the other posts just ask again. Someone is sure to help you out.
in case you didn't see the other post on display, please check out this link, it is a very good tutorial for repairing most of these problems, http://batee.com/corvette/dcrg/repair.htm. the main problem is the cold solder joints in the power supply module, don't forget to resolder all of these connections, otherwise the problem will continue
larry melton |
