Intake Manifold Gasket Replacemen
Im going to be replacing the intake manifold gaskets this weekend as there is a coolant leak that I can see coming from above cylinders 5 and 7. I have a few questions before I take this task on. Will I be able to remove the right and left runners along with the plenum in one piece? If not, should I just replace the runner to plenum/manifold gaskets also since there are already apart? Ive seen gasket kits that include these gaskets in the kit. Since I will be removing the fuel rails and injectors, are there things I should get to replace on these parts, like o rings or c clips and such? Is there any hints or tips that you veterns can lend me before I do this project? Any information will be greatly appreciated. Thanks!!
RE: Intake Manifold Gasket Replacemen
ORIGINAL: 85vette80821 Im going to be replacing the intake manifold gaskets this weekend as there is a coolant leak that I can see coming from above cylinders 5 and 7. I have a few questions before I take this task on. Will I be able to remove the right and left runners along with the plenum in one piece? If not, should I just replace the runner to plenum/manifold gaskets also since there are already apart? Ive seen gasket kits that include these gaskets in the kit. Since I will be removing the fuel rails and injectors, are there things I should get to replace on these parts, like o rings or c clips and such? Is there any hints or tips that you veterns can lend me before I do this project? Any information will be greatly appreciated. Thanks!! |
ORIGINAL: 85vette80821 Im going to be replacing the intake manifold gaskets this weekend as there is a coolant leak that I can see coming from above cylinders 5 and 7. I have a few questions before I take this task on. Will I be able to remove the right and left runners along with the plenum in one piece? If not, should I just replace the runner to plenum/manifold gaskets also since there are already apart? Ive seen gasket kits that include these gaskets in the kit. Since I will be removing the fuel rails and injectors, are there things I should get to replace on these parts, like o rings or c clips and such? Is there any hints or tips that you veterns can lend me before I do this project? Any information will be greatly appreciated. Thanks!! Cleaned parts, AND bolts and bolt holes is always good too. Nothin' like a bolt goin' back into a grit-free hole. Put string or fishin' line or a bread-bag tie on your injector retainer clips. If they go ballistic on ya', it's history. I suggest a TOTAL dry fit first, skipping tough bolts (first and last runner-to-intake (you'll see)), and no torqueing. Put a thin grease film on gaskets, and Trans-X on injector O-rings. TPI's are terrible for intake leaks, with all the components. |
