Minor oil leak continues 91 ZR1
Well I carefully replaced the two O rings between the oil lines and the oil cooler....apparently that wasn't the problem...still leaking oil. I'm unable to see where the oil is actually coming from..so I'm assuming I have to remove the shroud to be able to see the oil cooler better. It doesn't look like an easy job...any suggestions and advise on where to get an exploded pic of that area. To add insult to injury, when I removed the rubber oil lines from the cooler, apparently that slight bending caused another leak where the rubber hose attaches to the metal crimp....probably due to old age. I was told those rubber hose oil lines are no longer available. Any advise or suggestions will be GREATLY appreciated!!
