New Motor, Car Starts but shuts off
Hello All,
I am really scratching my head on this one. I just rebuilt my LT-1 from top to bottom. (See specs below) I dont have the full exhaust on yet and only have headers on. I went to start it for the first time and it started right up but quickly shut down (Loud as hell but sweet) I have already spent over $10,000 on this motor and it doesnt run. Please help me. Where do I start. 1995 LT-1 Vette LT-4 Heads & Intake 392 CI Stroker (Block Bored and Honed, Deck Plate, Even Deck Height) 1.6 Roller Rockers ZZ Performance Roller Cam 226-228 @50 110 Lobe Seperation Mahle Steel Crank Stroke 3.78 Coyles true roller timing chain and gears 58 mm TPIS Throttle Body (Coolant By-passed) Hooker Headers MSD Ignition (Coil, Distributor, 6A & Wires all MSD) Centerforce Clutch ACCEL 40 lb Injectors LT-4 Knock Sensor Module SRP Forged Floating Pistons with Airless Gapless Rings Borla Exhaust (No Cats) Removed EGR |
RE: New Motor, Car Starts but shuts off
Have you checked to see if you are losing spark or fuel? or injector pulse?
Did the security light stay on when it sarted? you might have a passkey problem unrelated to the new motor.
A fail-safe???
Either the oil pressure is not 'registering' by the ECM, as the motor starts, and the spark kills, or the fuel pump kills. OR, the ECM isn't telling the fuel pump to re-start (after the initial 2-second priming and shut-off). I think mech259 could tell you where to check these... |
