opti spark
I am a new vette owner. bought a 94 with 109,000 on it, did brakes, coolant, trans service. I have read alot about the dreaded opti spark. My car runs fine. Is there a mileage rec on replacement? how do you know when it is going bad?
richard |
RE: opti spark
Your way past the mileage averages of the life of an opti. That being said, my car has 140000 miles on the original opti. My car is a 1992 so you and I are in the same boat when it comes to Optispark's.Just keep an eye on your water pump,DO NOTwash your engine and hope a hose doesn't blow because if it does - your probably in a lot of trouble. I have heard of people washing their engine or somehow managing to get the opti wet and drying it out, then not really having any problems but coolant is a death blow to an opti. Here is some info:
OptiSpark History The OptiSpark (Opti) was introduced in 1991, with the LT1 as part of the 1992 model year. Why did they do the Opti? Even Gordon Killebrew doesn't have a clue. The Opti is made up of two sides, one side, the side against the engine, is an optical pickup. The pickup is made by Mitsubishi, and is a very reliable component. The optical system reads a disc that has marks in it. On the outer edge are 360 marks, inside that, are four marks. The outer marks create the so called "High Resolution" signal to control timing, the inner marks, or "Low Resolution" are used to signal fuel delivery. A common shaft joins the optical side with the high voltage side. The high voltage side is similar to any distributor, except it is much thinner. The unique part, the sides of the cap are sequenced, so all the odds are on one side, evens on the other! In 1995, the second generation of the Opti was released. It has a venting hose and is better constructed. Problems Codes can present themselves if an Opti is failing. These codes very by year, but for the earlier versions, codes 16 and 36 are bad(Note: these codes only apply to 1992 - 1995, 1996 uses ODBII and has different codes). This means the optical portion has a problem. Most likely, the error is caused not so much a failure in the optical portion, but the bearings having worn out, causing a wobble in the drive shaft. A common problem is when coolant from a bad waterpump leaks in. Coolant will eat the grease inside the sealed bearings. This causes the common shaft to wobble. If there is a wondering idle or a high RPM miss, you can blame a bad cap/rotor. The cap/rotor fails due to carbon tracing, caused by moisture getting into the Opti. Factory Options New Optis are available from the dealer. Also available is the Venting Hose Kit, that can be retrofitted to the original cap design. You can also update an earlier engine to the later Opti, by changing the timing cover and various internal parts related to the timing gear. I cannot advise a cap/rotor change. The labour is the same... and there is no guarentee that a rotor change will result in a long term repair. If your car is a 1995 or newer, then a cap/rotor change might just be worth investigating. Regardless of the vintage, removing the cap and sealing with RTV is a good idea. It might not be a bad idea to install a drain hose on the waterpump, to direct the weap holes output to the side, instead of on the Opti. I do not recommend the Ecklers or Mid-America cap venting system. It is a single hose, and as such does not create positive pressure. It might suck some stuff out, but I just don't see how it can without creating a complete loop. Aftermarket Options There are now a few options available: [ul][*]Dyna-Tech - This is a totally reengineered version of the Opti. A good idea for those who wish to maintain a stock look.[/ul] [ul][*]LTCC - This uses eight LS1 coils, and the Opti to read the data needed to fire the coils.[/ul] [ul][*]DelTeq - This is similar to the LTCC, but uses a Northstar coil pack.[/ul] Generic replacement Optis are not recommended. They don't include the cap/rotor and are of questionable reliability. |
RE: opti spark
thanks. I guess I'll wait and see what happens. I know some service advisors at different dealers and will try to get them to do an nvh for me to see if it's already been done but that only works if a dealer did it
Richard |
