Passenger lock slow
Have to hold the switch a second for the slow passenger side to lock when getting out.
Can it be rebuilt? Lubed(graphite is cool stuff)? Any help is appreciated. Thanks J |
RE: Passenger lock slow
1st, you need to check voltage out of switch to see if you are getting B+ (Battery Voltage). If you are, then you probably need to replace the lock actuator and/or lube the lock mechanism. A1 sells rebuilt actuators for around $60.00. Most auto parts carry A-1 Cardone parts. [8D]
