Passenger-side door panel removal
Hi I sure could use some help I am replacing the dreaded outside window seal I have done the driver's side and I'm now working on the passenger side however I cannot seem to remove the door panel, I have removed a screw hidden behind the courtesy light and a screw behind a door lock.
But it still does not seem to want to come off as if something is holding it near where the power window switches is, is there anyone out there that can help me with this? |
RE: Passenger-side door panel removal
Yep. There is a screw behind the power window switch.Pop the power window switch out and get a flashlight and look behind it. It sits in the hole for theswitch way back there. It connects to a little bracket that is connected to the door panel. The driver side does not have this screw.
