power window problem
My windows worked fine until this morning. I went to put up my pass.side window and nothing happened. Driverside still works fine. When hitting the switch for the pass.side you can here a faint click from the pass. door.Could of my motor just up and died. It wasnt slow or anything before.
RE: power window problem
ok i checked voltage at the motor.i unpluged the wires from the motor and i have 11.94 volts on both the blue and brown wire .i checked this with both door switches. is this telling me the motor is bad???
