Radiator Fan
Hi Guys, does anybody know how to make the Radiator Fan come on sooner? Right now my Fan is not coming on until the engine reaches 240 degrees. Thanks.
Do you know what temperature that the fan is supposed to turn on at? It depends on the sensor on how you would have to check it. If the temperature is something around 200 degrees, you could test it by putting it in boiling water which is around 212 degrees depending on your altitude.
Thanks 73Shark, I’m going to buy a new Temperature Sensor for the Fan. Wondering if you know where it’s located on a 88’ Vette?
