Speedometer problems
I am trying to fix the speedometer on a 87. The manual states to check E pin on the IP connector for a reading of 10 volts. Where is the IP connector? I believe I have a grounded wire some where as this problem began after I upgraded the transmission. Without a wiring diagram I am having a hard time understanding the circuit between the VSS, ECM, and IP. Any help will be appreciated.
