still ABS problem
Bakc again
Still looking for an answer for abs problem. Having abs problems. did a voltage sheck on terminals 43-44&45-46 at abs computer and at connector break out. Have a varying reading at both places and unit has now started going off when put in gear going approx 5mph either forward or rearward. light does nto come on untill unit is activated above 40 mph and codes are still 33 & 37. Cannot find used abs at a reasonable price so want to am\\make sure before just slapping in another one. have cleaned master and re-bled system. Good pedal will be road testin again today but bet problem still there as nothing electrical has been done and codesd indicate continuity prob. HELP!!!! bj |
RE: still ABS problem
i'm havng the same or close to the same probem.i have a 92 automatic and this just started to happen. does your ASR light come on or activate when you are in park and you reeve up your engine? can someone please help us ?
What year is your car?
1st of all, are you checking the wheel sensors with an A/C volt meter? Sounds like to me that your wheel sensors are bad. Those codes are wheel speed sensor continuity. Check your wiring to the rear wheel speed sensors to make sure there is no breaks in the wiring.
