gary1984 |
05-17-2016 07:52 AM |
Theft Deterent System Horn Issues 1984
Hi, My 1984 corvette was sitting in the parking lot and the security system was unarmed. The horn started going off continuously. I went over and unlocked the car by both doors with keys thinking maybe the TDS was maybe armed. The car would not start. I put the key in the ignition and turn it to start the car and got nothing but my horn going off. After doing some research I opened up the DIC area and removed the 10 amp fuse to disable the TDS and bypassed the starter relay with jumping the outer posts in the starter relay deterrent . The car then started but the horn still rang continuously. I went and bought a new horn relay thinking that may be the issue and put it in. Horn still blows. I can now start and drive the 1984 corvette but had to pull the horn relay and thus have no horn. I did find if the driver's door is open the horn quits. When I shut the driver's door it goes off again. This after disabling the TDS system. What inside the door panel would cause this? Any help would be appreciated! Help! Thanks Gary
