Timing Adjusment
Dose anyone know if there is a way to adjust the timing on a 94 lt1. I have looked in the book on it and it dosn't say anything about the timing other than when you put the opt-spark back on. My car sounds like the timing is off when I try to crank it and it dosn't have near the power of other 94's and 95's that I have drove. The car only has 81,000 mile on it.
RE: Timing Adjusment
Hello,my friend. I think the LT-1 does not require any adjustment.It's possible you may need to do a tune up and change your opti-spark.Hope you find a solution.good luck.Your friend,Joe.
Thanks for the help. I found out that one of my cooling fans wasn't working and the engine was getting around 240 to 250 degree's causing the engine to lag power and strain real bad.
