Tire size
Anyone know if I can safely put a 315 size tire on the rear of my 92 with stock 9.5 width wheels? Thanks for the input.:)
RE: Tire size
I hope you get some responses to this one. I plan to do the exact same thing in the Spring. Good luck......
mypetu39 |
RE: Tire size
Hello,guys.I think you can put that size tire on your car,but ifI were you,go with the '11 rim.Like the Grand Sports i have on my '96.the rims are about $500 each(without tires,of course),and you don't really need to get the GS's.You can get the saw-blades and the silver 5-spoke wheels in that size too.And they WILL fit your car.Good luck to you.
RE: Tire size
Standards published by The Tire and Rim Association for a 315 width in a 40 aspect ratio (315/40) call for a rim width from 11-12 inches. 9.5 inches is far too small.
RE: Tire size
A 9.5 inch rim is pretty small for 315s. Generally, you can figure a 1/2 inch per side over the limit. 9.5 inches is 241 mm. An inch (two half an inch overlaps on each side) is another 25.4 mm for a total of 265::: basically a 265 of 275 is about as big as you should go.A 315 is an inch and a half beyond that, so I would expect problems.
by the same computation, an 11" rim is just about perfect for that size. |
