vac. line HELP PLEASE ?
Is there any where i can find a diagham for the vac. lines that run under the TPI? while changing my thermostat, some hard lines came unplugged in the area right behind the thermostat and under the plenum.
I just want to make sure I plugged them to the correct spot. Because now it just doesn't seem to idle quite right. I also put in new plugs and wires.. LIKE MY WIFE ALWAYS TELLS ME--IF IT AINT BROKE, DON'T FIX IT. BUT I NEVER LEARN ! Any help would be great THANKS |
RE: vac. line HELP PLEASE ?
They go to the vacuum control solenoid for the EGR valve. 1 is source vacuum and the other goes to the EGR valve.
Mech259,
You are the man. |
[IMG][/IMG]i recently recieved this thanks to yet another helpful corvette owner. maybe it will help others as well
[IMG]local://upfiles/2755/7DC7A45BCDAB48CAA530096A1571B8E3.gif[/IMG] |
So is it OK now, my friend?
I DID HAVE ONE OFF. IT SEEMS TO RUN BETTER !! THANKS AGAIN
