where's the voltage regulator
mine is 86 vette cpe...im replacing the alternator . but i cant find the voltage regulator. its not in the haine's guide either. anybody knows where the regulator is located
RE: where's the voltage regulator
Had a suspicion on this one... just checked and it appears I was right. The voltage regulators for our cars are actually inside the alternator. No wonder you couldn't find it!! *laughs*
So, yeh, if you're putting in a new/refurb alternator, you are also replacing your voltage regulator. Good news, eh? :) |
LOL. no wonder i couldnt find it. what threw me off was when i wnet online at napa auto looking for parts...it was recommmending i replace it too ....thanks topspeed. btw, the gauges was reading 18v and the red charging light is on...ran a code reader...gave me a code 53
ORIGINAL: bobbiebello LOL. no wonder i couldnt find it. what threw me off was when i wnet online at napa auto looking for parts...it was recommmending i replace it too ....thanks topspeed. btw, the gauges was reading 18v and the red charging light is on...ran a code reader...gave me a code 53 Keep us posted on how you make out with that! :) |
That's NAPA for you...typical genuises...brilliant:D
Code 53 means ECM voltage sense wire has detected voltage outside of normal charging range. Chances are your regulator has shorted and your alternator is charging full tilt with no control on it. Hard on a battery, also have your battery load checked and check cables and charging wire from alternator for good, clean, tight connections.[8D]
under normal operating conditions what should the "volts" be? on my '87 it usualy reads from 13.6 to 14.2.
That's SOP. Usually no more than 14.5. More than that, I would check connections or alternator.
the volt meter was reding 13-14 v before the alternator started reading 18v with the red ligght on. im replacing the alternator ...ill keep u guys posted
replaced the alternator today...checked all cable connections. evrything seems back to normal. charging to 13.5-14v. it appears that the first alternator i got conked out. it was under warranty. ill keep u guys informed on how its holding up...at this point it looks like green light thanks
