2001 vette throwing codes 1277,1571,1637 and 1638.
Hello everyone,
I have a 2001 corvette (base Model). I am having the following problem. After cranking the carm all of the lights go out execept the traction control light. In the DIC, i receive the following messages: Service vehicle soon Service active handling Service traction control the error code are as follows: PCM 1571 1637 1638 TCS 1277 H C Here is what I've done so far. I pulled the EBCM and sent it out to a place in Duluth, Ga. They claimed to have rebuilt the unit. I put it back on the vehicle only to see the same error messages again. Since the unit looked exactly like when I pulled it off, I called and told the folks what the errors was and sent it back to them, they kept the unit for a week and sent it back. I put it back on the car yesterday only to see the same messages. After doing some research on the web, I decided to pull ground connectors G103 and G108. and clean them. They were corroded. after reassembling both connectors, I started he vehicle to see if there was any change. the results were the same with one additional error code: PCM 0530. I am stumped as it seems the EBCM isn't the problem. Can anyone help me with this? Is the ABS pump bad? Is it even safe to drive the car with the error message being displayed? I am really at wits end, and would like to put this to rest but don't know what to do. I appreciate any help you guys can give me. Thanks in advance, Naytedawg |
