ac line after longtube install
hello! i just had a set of long tube headers installed on my 97 vette and now the ac line is pinched in between the header and the wheelwell and has burned right through the ac line. does anyone know where i can get a longer line so i can reroute it behind the header? has anyone encountered this problem b4 or have any other suggestions? thanks for any help you guys can provide!
RE: ac line after longtube install
also i believe this is the low pressure line..if that helps any.
Call around to some local auto radiator/AC repair shops and explain your problem, they should be able to make up a new hose assembly to route around any obstruction, then have them do the repair, evacuate, and re-charge so they can check for leaks and give you some kind of warranty on their work.
i think thats probably going to be my best bet...i will give that a shot. thanks
