C-5 Passenger Window
I've got an -04 Commemorative Coupe w/ 6-speed and have had it since March. Drive it only on sunny days, holidays, vacations, weekends, etc. and she's low mileage and nice. However, just the other day, I went to roll down the passenger window and she clicks but won't open.
Is there an easy fix (fuse) that I can do short of a trip to the dealership to remedy? Thanks, [8D] gato |
RE: C-5 Passenger Window
From another C5 owner....
I just had to deal with this today. I was suppose to go somewhere and it was raining......I had parked the car with the windows down in the garage.....went to put them up and the "pilot's" side refused to budge...had the clicking noise in the door control module like others have described. Slamming the door didn't help so I pulled the door speaker and trim panel. Tapped on the regulator motor with a rubber mallet until it suddenly burst back to life. Ran it up and down several times throughout the day and works as advertised. |
I have the same problem with my window, did you get your problem fixed? If you did please reply and tell me what you did . THANKS for any info you can give me..........
:)I did what you said and it worked! Who would beleive a couple of little hammer taps would fix theproblem, but it did and it only takes about 30 minutes to do it. I thought it might be a big pain in the butt, but it was an easy fix! Thanks........
http://www.cccorvette.org/tech.html check out this website they have alot of fixes for vettes
