change oil display on dic
Ok here's a new one. I've just changed my oil and when i try to reset the display back to a 100% it displays blank then goes to 20% not 100%. Then it will dispaly change oil soon. Anyone seen this problem? Oh it on a 1997. Thanks
RE: change oil display on dic
Are you following the reset procedure exactly? How did you do it?
Thanks for reply. reset same as i have in the past pushed in reset button till display clears. but know it just sticks on 20%. then goes to change oil soon.
If you have the car running this happens. Key on engine off then reset.
Hey thanks a lot that did the trick.
