C5 auto tranny overheat
Not sure what the normal transmission temperature would be but since the engine typically runs at 200 degrees, then 200 doesn't seem high. So I'm guessing you're thinking that the sensor is bad and needs to be replaced? Not having ever seen a C5 on the lift, I really can't answer the question is it replaceable on the car. Maybe someone else can pick this up and answer your question.
