Headlight Popup
When my 2001 C5 is running the lights won't come up, however when I turn off the motor with the ignition on the lights will come up.
Anyone heard of this? Thank You, Jay Collett |
RE: Headlight Popup
yes its is probably the headlamp opening door actuator control module, if not that there is a slight chance it is the headlight switch. I'll post the schematic so that you can see the circuit.
RE: Headlight Popup
Jay,
My C5 has started doing this also. Did you fix yours? What did you do? Thanks, Dennis |
