Headlights not popping up
Hey, has anyone had issues with headlights not popping up? Still lighting up, doesn't sound like the motor. Not sure where to start.
Is 12 volts getting to the headlight motors when you try to raise or lower them? If not then you need to go back and see where you're losing the 12 volt signal |
Headlight not popping up
Originally Posted by 73shark
(Post 74838)
I would start by measuring the voltage at the connector at the headlight motor itself. You can do this with either a test light probe or a digital multimeter.
(Post 75094)
Now it sounds like the plastic gears need to be replaced by the available metal gears in the aftermarket.
(Post 75252)
Thank you! |
You will need to go to the Corvette aftermarket suppliers such as Corvette Central, Wilcox, Zip, etc. Try Googling Corvette headlight motor metal gears and see what you get.
